Cisco USB Console port connection
matloweBE
I have a pair of new 2960S-48TS-L switches which have the new USB console connector on them as well as the usual RJ45 type.
I thought I'd try the USB out so I got myself a USB to MiniUSB cable and downloaded the driver from CCO.
It worked straight off, but if I unplug the USB cable from either the switch or the laptop end, the session hangs and only recovers if I restart whatever application I am using and reconnect (I've tried hyperterminal, Putty and Tera Term so far)
This is obviously not ideal if working in an environment such as a lab where i need to go between different devices on the console, has anyone else tried this and had similar results?  If so, did you find a fix?
many thanks
Mat
Shelley Bhalla
Level 3
Level 3
I have not heard of any issues elsewhere so far.
1. Try another PC/laptop
2. Try other type of OS (win7, winxp etc)
3. Try removing the drivers and re-install.
http://www.cisco.com/en/US/docs/switches/lan/catalyst2960/hardware/installation/guide_stack/HGcliSET.html
Shelley
Cisco TAC.
