[SLM2024] and compatibility with GLC-SX-MM or GLC-LH-SM
DavidCisco2950
Hello, I would to know if GLC-SX-MM or GLC-LH-SM device are compatible with Cisco Small Business SLM2024.
The documentation says that MGBSX1 and MGBLH1 are compatible with this switch.
Thank a lot
David
Ce message a été modifié par: DavidCisco2950
Fabienne Stephanoff
Can you clarify which one of those switches apply in your case:
SLM2048, SLM2024, SLM248G, SLM248P, SLM224G,
SLM224P Smart Switch
Fabienne
Thanks you for your answer.
I’m sorry, the right number is SLM 2024
Thanks you.
No problem. I double checked for you and unfortunately, only the following GBICs are supported in this platform:
MGBSX1 Gigabit SX Mini-GBIC SFP Transceiver
MGBLH1 Gigabit LH Mini-GBIC SFP Transceiver
MGBT1 Gigabit 1000 Base-T Mini-GBIC SFP Transceiver
MGBLX1 1000 Base-LX Mini-GBIC SFP Transceiver
Cheers,
Fabienne.
