Showing results forĀ
Search instead forĀ
Did you mean:Ā
Cisco VOIP takes Data vlan insted of Voice vlan
awabalhassan
Hi all
I have this VOIP device and when i start it the device pulls the wrong VLAN, it pulls DATA VLAN instead of Voice VLAN.
note that switchport is configured as Voice.
please i need help on this one
thank you in advance.
6 Replies 6
Ibrahim Ajinah
What kind of VOIP device is that ? if its Cisco make sure CDP is enabled in the switch , if its other than Cisco make sure LLDP is enabled
Joseph W. Doherty
How is the port actually configured?
What's (precisely) the VoIP device?
here is an example of configuration
switchport access vlan 10
switchport mode access
switchport voice vlan 101
spanning-tree portfast
spanning-tree bpduguard enable
and the device is cisco
Thanks for giving us the example of configuration. Can you be more specific about the device? Knowing that it is Cisco is a good start. Knowing exactly what type of Cisco device it is wound be helpful.
Rick
we have 3 types of devices
7941
7861
7841
post the output of:
sh vlan
sh vtp status
of the device where this port is configured on.
