cisco VS juniper VRRP
dabur10376004
Level 2
Level 2
we have two senario as below.
we have cisco 4510R+E & Juniper switch. we need to run VRRP between them for redundency. its connectivity is as below
cisco 4510 10Gb connect with juniper 10Gb so we can get 20 Gb or 10 Gb?
we have 2 nos of cisco 4510R+E ,we need to run VSS between them for redundency. its connectivity is as below
Cisco 4510 10Gb connect with another cisco 4510 10Gb so we can get 20 Gb or 10 Gb?
another question, which scenario will be best for us. based on that we will procure juniper or another cisco 4510
kindly suggest on priority basis.
7 Replies 7
Philip D'Ath
Meraki Community All-Star
You come to a Cisco support form and ask if you should buy Juniper?  Why would you even want to introduce multi-vendor complexity into your network.
A single 10Gb/s link provides 10Gb/s in each direction, for a total of 20Gb/s of bandwidth.  If you are considering VSS you really should be using at least two links between the switches for redundancy.
thanks for your reply.
please confirm on below point.
Q1.  Cisco 4510 2 nos of 10Gb connect with juniper 2 nos of 10Gb & running VRRP , can we get total bandwidth 20 Gb or 10 Gb?
Q2.  Cisco 4510 2 nos of 10Gb connect with another Cisco 4510 2 nos of 10Gb & running VSS,can we get total bandwidth 20 Gb or 10 Gb?
could you Please provide some pros & cons on both scenario. it would be helpful for us.
Answer:- At any given point of time you only get 10GB output. Let me give you example:
suppose you are connecting 2 10Gig link between the switches you are achieving kind of load/sharing and any given point of time traffic will be flowing through only one link.The only advantage is that you have is that when you do etherchannel which means bundling of two link itto one. In that case STP will see 2 links as 1 which would avoid one of the Port going into blocking if you dont have Port channel.
VRRP is the protocol used for redundancy and not for any increasing of bandwidth.
Answer:- Please read our what is VSS that would help you in understanding. VSS is nothing but have two physical chasis bundling ito one. Still you dont get the bandwidth of 20gig.
Here is the explanation of what VSS is:-
https://supportforums.cisco.com/document/124626/virtual-switching-system-vss-configuration-cisco-4500-series-switches
Pros:- VSS has lot of advantage.
Inayath
***Please do not forget to rate the post if helpfull****
thanks for your prompt support.
I am just concern more about uplink bandwidth if we are adding 2 nos of 10G port each.
Actually I am just confusing that if different vendor switches (cisco & juniper) are connecting to each other like uplink (10Gx2port each). in that case uplink bandwidth will be 20 Gb or 10Gb if we are making ether channel between them.
if we are using cisco switches & connecting to each other like uplink (10Gx2port each). in that case uplink bandwidth will be 20 Gb or 10Gb if we are making ether channel between them.
Theoratically or sales point of view saying is bandwidth 20Gig.
But actually it will be 10 gig.
Remember this:
4500-===two link of 10 gig ===4500
Now as you see 10 gig connectivity ( 10*2=20gig) output is the theoritically way of explaining. But when the traffic flows from one 4500 to 2nd 4500 the traffic will be flown only through one link hence only at any given point of time you can send 10gig of traffic only.
question:
Answer:-When you bundle that doesnt mean that the bandwidth will be 20gig. Its wrong way of explanation. If you want to achieve 20gig then you need to increase the bandwidth.
thanks for your response.
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages wha2tsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
When you bundle multiple Ethernet ports (which can often be done even between different vendors using LACP), you have more aggregate bandwidth; the bandwidth sum of all your ports.  However, also often, individual flows will only use a single port, and if so, the maximum bandwidth for a single flow is the bandwidth of a single port.
So, for a pair of Cisco 10g ports, Etherchanneled, multiple flows can take advantage of the 20 gig, but any one flow will not be able to obtain more than 10 gig.
Also with bundled Ethernet ports, Cisco hardware doesn't take into account actual port loading, so two or more flows might use one port, while the adjacent port is even totally unused.  Even with multiple flows, you seldom will see multiple flow bandwidth take full advantage of all the aggregate bandwidth.  I've found, for two links, multiple flows get about a 50% bandwidth boost, not the 100% you would hope for.  I.e. in average, two 10g Etherchannel links will perform somewhat like a single 15g link.
Lastly, when working with Etherchannel, it's important to insure the hashing algorithm being used well distributes your traffic.  A "bad" choice can cause all your traffic to use just one link.  (If supported, hashing both source and destination IP addresses often works well.)
