Cisco VSS strange syslog message
jackson.ku
Level 3
Level 3
Dear All,
My Cisco Catalyst 6509 VSS switch have the following strange syslog message :
Dec 17 12:23:36.591: %SM-SW1_SP-4-PERSIST: Persistent event 'link_down' did not leave the current state 'link_down': pm_port 34/7
Dec 17 12:23:36.600: %LINK-3-UPDOWN: Interface GigabitEthernet2/2/7, changed state to down
Dec 17 12:23:36.599: %LINK-SW1_SP-3-UPDOWN: Interface GigabitEthernet2/2/7,changed state to down
Please advice me what the "%SM-SW1_SP-4-PERSIST" mean? ( Please do not post the comment from Cisco error message decoder )
Best Regards,
Jackson Ku
Yogesh Ramdoss
Jackson,
SM ==> State Machine
SW1_SP ==> Switch Processor (SP) in Switch #1 of the VSS setup
4 ==> Severity Level of the message
PERSIST ==> Message type
PM ==> Port Manager (process managing the ports in VSS)
If 34/7 is a SPAN destination port, this message should be cosmetic, when the SPAN session becomes active (or configuring this port as SPAN destination). When a port transition from one state to other, the SM of the port report state change(s).
Please review following bug:
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCth01851
Hope this helps.
- Yogesh
Yogesh Ramdoss
Jackson,
Hope this helps.
- Yogesh
You are correct, the 34/7 is a SPAN destination port.. Many thanks for your answer ...
Best Regards,
Jackson Ku
How can I check the physical port number which process manager? Such as the case , 37/4 is not the real port #, how can I know the real port number? Thanks!
In VSS, please do "show switch virtual slot-map". The results should provide you the mapping between virtual slot # and physical switch/slot number.
From my lab setup:
VSS#sh switch virtual slot-map
Virtual Slot to Remote Switch/Physical Slot Mapping Table:
Virtual    Remote      Physical   Module
Slot No    Switch No   Slot No    Uptime
  17        1              1        3d16h
  18        1              2        3d16h
  19        1              3          -
  20        1              4          -
  21        1              5        3d16h
  33        2              1        3d16h
  34        2              2        3d16h
  35        2              3          -
  36        2              4        3d16h
  37        2              5        3d16h
You can see here, Virtual slot 34 = Switch 2 / Module 2.
Hope this helps.
Yogesh
