cisco works ----syslog messages
ilnaiduccna
Hi all,
I have Cisco works LMS 2.6 and I am new with this.
My manager want whenever if any one login into the device (one of the core switch) / made some changes then we need to get an Email.
Can somebody help out me.
Naidu.
cauley.shane
You will need to create a filter to extract the VTY configure and setup custom report. Then you will be able to schedule the report to be sent to your e-mail.
Shane Cauley
Cheyenne,WY
Hi Shane,
Nice to see your quick reply and thank you.
Can you suggest me step by step like from where i have to start, because i am very new to cisco works.
It will be very help full to me as i need to done this ASAP
Naidu.
Hi all,
Any luck.
Naidu.
