04-15-2019 05:43 AM
So I have one Cisco ws-3750x-48p that one of the fans is just stuck on full load the whole time, It seems like its just that fan port on the switch itself, I can swap out fans and it does it for each one, here are the logs from env all, power and fan.
Also on the fans themselves the lights are solid green.
I have tried to do a search and cannot come up with anything, so any help would be highly appreciated.
Thanks.
Switch#show env all
FAN 1 is OK
FAN 2 is OK
FAN PS-1 is OK
FAN PS-2 is NOT PRESENT
SYSTEM TEMPERATURE is OK
System Temperature Value: 20 Degree Celsius
System Temperature State: GREEN
Yellow Threshold : 46 Degree Celsius
Red Threshold : 60 Degree Celsius
SW PID Serial# Status Sys Pwr PoE Pwr Watts
1A C3KX-PWR-715WAC DTN1652K0ZJ OK Good Good 715/0
1B Not Present
SW Status RPS Name RPS Serial# RPS Port#
1 Not Present <>
Switch#show env power
1B Not Present
Switch#show env fan
FAN 1 is OK
FAN 2 is OK
FAN PS-1 is OK
04-15-2019 07:00 AM
04-15-2019 09:56 AM
Thanks for the quick reply, but I have tried several different fan units from different 3750 switches and they all do the same thing in that same spot.
04-15-2019 11:09 AM
