Cisco WS-C2960X-48FPS-L - Key exchange algorithms
RS19
Level 4
Level 4
I wanted to know whether Cisco WS-C2960X-48FPS-L with IOS 15.2(6) E2 supports any of the below
Key exchange algorithms:
  • curve25519-sha256
  • curve25519-sha256@libssh.org
  • ecdh-sha2-nistp256
  • ecdh-sha2-nistp384
  • ecdh-sha2-nistp521
  • diffie-hellman-group-exchange-sha256
  • diffie-hellman-group16-sha512
  • diffie-hellman-group18-sha512
  • diffie-hellman-group14-sha256
    In the switch when I did show ip ssh, I got the below output. So wanted to understand if any of the above is supported.
    SSH Enabled - version 2.0
    Authentication methods:publickey,keyboard-interactive,password
    Authentication Publickey Algorithms:x509v3-ssh-rsa,ssh-rsa
    Hostkey Algorithms:x509v3-ssh-rsa,ssh-rsa
    Encryption Algorithms:aes128-ctr,aes192-ctr,aes256-ctr
    MAC Algorithms:hmac-sha1,hmac-sha1-96
    Authentication timeout: 120 secs; Authentication retries: 3
    Minimum expected Diffie Hellman key size : 1024 bits
    IOS Keys in SECSH format(ssh-rsa, base64 encoded): abc.com
    ssh-rsa AAAAB3NzaC1yc2EAAAADAQABAAAAgQCbfyQ/fF6GhVNhvqPsPpJXIt7utjxRkHV21FtZlJr0
    v9JTbRA67vrPtPai011425N+wU+vAm2Xl70mPAm+A/JEuNnSn0Tz/tJWrSCJaZ9IK+j/ZZ5z9WqXJMQi
    b+UiXc/V0+uScuLDhf2bxaeaNaksx4dJezPiNssdvri3jnfsrQ==
RS19
Level 4
Level 4
any help
RS19
Level 4
Level 4
any help on this ?
Hello @RS19 ,
it seems that in IOS 15 you only have these options:
(config)#ip ssh client algorithm kex ?
diffie-hellman-group-exchange-sha1 DH_GRPX_SHA1 diffie-hellman key exchange algorithm
diffie-hellman-group14-sha1 DH_GRP14_SHA1 diffie-hellman key exchange algorithm
Hope it helps.
Regards, LG
*** Please Rate All Helpful Responses ***
RS19
Level 4
Level 4
which model switch you tested the above ?
