Cisco WS-C4500X-16 10G twinax cable support issue
We have going to procure Cisco Data Center Switches but before that we need check compatible issue of 10G Twinax cable for Cisco  WS-C4500X-16
Sending here the sh version output -
Cisco IOS Software, IOS-XE Software, Catalyst 4500 L3 Switch Software (cat4500e-UNIVERSALK9-M), Version 03.04.00.SG RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2012 by Cisco Systems, Inc.
Compiled Wed 05-Dec-12 04:38 by prod_rel_team
Cisco IOS-XE software, Copyright (c) 2005-2010, 2012 by cisco Systems, Inc.
All rights reserved.  Certain components of Cisco IOS-XE software are
licensed under the GNU General Public License ("GPL") Version 2.0.  The
software code licensed under GPL Version 2.0 is free software that comes
with ABSOLUTELY NO WARRANTY.  You can redistribute and/or modify such
GPL code under the terms of GPL Version 2.0.  For more details, see the
documentation or "License Notice" file accompanying the IOS-XE software,
or the applicable URL provided on the flyer accompanying the IOS-XE
software.
ROM: 15.0(1r)SG6
SG_CEB_COR4500X_01 uptime is 17 weeks, 4 hours, 47 minutes
Uptime for this control processor is 17 weeks, 4 hours, 50 minutes
Running default software
Jawa Revision 2, Winter Revision 0x0.0x1C
Last reload reason: power-on
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
License Information for 'WS-C4500X-16'
    License Level: ipbase   Type: Permanent
    Next reboot license Level: ipbase
cisco WS-C4500X-16 (MPC8572) processor (revision 4) with 4194304K/20480K bytes of memory.
Processor board ID JAE173703FE
MPC8572 CPU at 1.5GHz, Cisco Catalyst 4500X
Last reset from PowerUp
1 Virtual Ethernet interface
48 Ten Gigabit Ethernet interfaces
511K bytes of non-volatile configuration memory.
Configuration register is 0x2101
is it possible or support 10G twinax cable? Please ............
regards
Mannan
TwinAx is supported.
5 Replies 5
Leo Laohoo
Yes.  Read THIS.
thanks for your reply.
sorry I couldn't find out docs in ref URL. Can you please tell me specific pages?
regards
Mannan
As Leo said, 4500x support 10Gig twinax
see link and look for 4500x section:
http://www.cisco.com/c/en/us/td/docs/interfaces_modules/transceiver_modules/compatibility/matrix/10GE_Tx_Matrix.html
thanking you all for valued time & comments.
regards
Mannan
