Cisco
ciscousernow
Visitor
We did a cisco IE 9320 code upgrade and it failed. it is in a boot loop and unable to get into rom mon mode. Can TAC help me retreive the logs as to  why it failed
Mark Elsen
  - @ciscousernow   Yes , but then you need to contact TAC directly ,
  M.
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
Hello @ciscousernow welcome to teh community! Yes, Cisco TAC can help you retrieve logs to determine why the code upgrade failed, even if the switch is in a boot loop and you can't manually enter ROMMON mode. You can open a ticket here.
https://www.cisco.com/c/en_uk/support/index.html
Please mark this as helpful or solution accepted to help others
Connect with me https://bigevilbeard.github.io
