Cisco1921 Initial Login
Hamood Rehman
     How do I set a password? new Cisco 2911 router,
C1900 Software (C1900-UNIVERSALK9-M), Version 15.1(4)M4,
yourname>enable
% No password set
yourname>configure terminal
% Invalid input detected at '^' marker.
yourname>usenam
yourname>usenam?
% Unrecognized command
yourname>passw
yourname>passw?
yourname>secre
yourname>secre?
yourname>
Did you plug console cable into aux port instead into Console port (blue)?
6 Replies 6
mahmoodmkl
Level 7
Level 7
can u try with cisco as username and password
yourname>cisco
Translating "cisco"...domain server (255.255.255.255)yourname>cisco
first type enable then when prompted for password enter cisco
yourname>enable
% No password set
Yes I did, should have taken smoke break an hour ago....
yourname#
yourname#
yourname#conf t
Enter configuration commands, one per line.  End with CNTL/Z.
yourname(config)#usern
yourname(config)#username yourname#
yourname#
yourname#conf t
