copy the configuration of 1 interface to many
netone.cisco
Hi all
I would like to know if is there a way to copy the configuration of 1 interface to many ex:
on switch huawei i can find:
copy configuration source GigabitEthernet1/0/1 destination GigabitEthernet1/0/2  GigabitEthernet1/0/3
Mauro Silva
mahmoodmkl
Level 7
Level 7
if it cisco thn u can use interface range command which allows to configure multiple interfaces at a time
hi mahmoodmkl,
thanks for your help, but i would like to copy, not configure. if a do int range i will need to configure
On the Nexus platforms you can create a port profile, and then tell a range of interfaces to inherit from the profile.
Otherwise, int range is the only option that I can think of .
