Cisco1921 IP base features
jacinto1m
Could someone confirm that the below features are included on the IP Base IOS in a Cisco1921?
•         NHRP
•         GRE Tunnel
•         EIGRP stub routing (VRF)
•         GRE Tunnel IP Source and Destination VRF Membership
Any help is much appreciated.
Peter Paluch
Hello Che gue,
I suggest using the Cisco Feature Navigator at http://cisco.com/go/fn - use the "Search by Platform" link and select the appropriate platform and IOS image. In the resulting feature list, you will see all the supported features in the particular IOS version and feature set.
One comment, though: EIGRP Stub Routing is not related to VRFs.
Best regards,
Peter
Hello Peter,
Brilliiant page, I did not know about it. Thank you very much.
Best Regards
Please rate helpful posts and close solved questions
Best Regards Please rate all helpful posts and close solved questions
