CISCO7609-s'routing interface attend MSTP caculation
zhuch
On a pair of my CISCO7609-s (engine:sup720-3B IOS Version:12.2(33)SRD4),some interfaces is configured as routing interface but also them are attend MSTP caculation and i really caught BPDU packet go out from these ports. Why?
------------------ show version ------------------
Cisco IOS Software, c7600s72033_rp Software (c7600s72033_rp-ADVIPSERVICES-M), Version 12.2(33)SRD4, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2010 by Cisco Systems, Inc.
Compiled Mon 22-Feb-10 04:44 by prod_rel_team
ROM: System Bootstrap, Version 12.2(17r)SX5, RELEASE SOFTWARE (fc1)
BOOTLDR: Cisco IOS Software, c7600s72033_rp Software (c7600s72033_rp-ADVIPSERVICES-M), Version 12.2(33)SRD4, RELEASE SOFTWARE (fc2)
HIHK-PS-IMS-CE03-CISCO7609 uptime is 36 weeks, 5 days, 20 hours, 10 minutes
Uptime for this control processor is 36 weeks, 5 days, 20 hours, 12 minutes
System returned to ROM by reload at 00:43:40 UTC Wed Jun 22 2011 (SP by reload)
System restarted at 00:54:08 UTC Wed Jun 22 2011
System image file is "sup-bootdisk:c7600s72033-advipservices-mz.122-33.SRD4.bin"
Last reload type: Normal Reload
Last reload reason: Reason unspecified
cisco CISCO7609-S (R7000) processor (revision 1.0) with 458720K/65536K bytes of memory.
Processor board ID FOX1306G1GW
SR71000 CPU at 600Mhz, Implementation 0x504, Rev 1.2, 512KB L2 Cache
Last reset from s/w reset
23 Virtual Ethernet interfaces
340 Gigabit Ethernet interfaces
2045K bytes of non-volatile configuration memory.
8192K bytes of packet buffer memory.
65536K bytes of Flash internal SIMM (Sector size 512K).
------------------ show running-config ------------------
Building configuration...
Current configuration : 82331 bytes
! Last configuration change at 20:05:28 UTC Mon Mar 5 2012 by maoliuji15208989284
! NVRAM config last updated at 15:43:37 UTC Fri Mar 2 2012 by maoliuji15208989284
version 12.2
spanning-tree mode mst
spanning-tree mst configuration
name Radio_BST_MSTP
revision 1
spanning-tree mst 0 priority 24576
interface GigabitEthernet1/11
description TO-ABC
ip vrf forwarding A
ip address 10.80.123.130 255.255.255.128
speed 1000
duplex full
standby 108 ip 10.80.123.129
standby 108 timers msec 200 msec 600
standby 108 priority 120
standby 108 preempt delay minimum 120
interface GigabitEthernet2/1
description TO-CDE
ip vrf forwarding A
ip address 10.80.126.2 255.255.255.128
speed 1000
duplex full
standby 101 ip 10.80.126.1
standby 101 timers msec 200 msec 600
standby 101 priority 120
standby 101 preempt delay minimum 120
end
------------------ show spanning-tree active ------------------
MST0
  Spanning tree enabled protocol mstp
  Root ID    Priority    0
             Address     0000.0000.0000
             Cost        0
             Port        3329 (Port-channel1)
             Hello Time   2 sec  Max Age 20 sec  Forward Delay 15 sec
  Bridge ID  Priority    24576  (priority 24576 sys-id-ext 0)
             Address     0023.5ed9.8600
Interface           Role Sts Cost      Prio.Nbr Type
Gi1/11              Desg FWD 20000     128.11   P2p Pre-STD-Rx
Gi1/12              Desg FWD 20000     128.12   P2p Pre-STD-Rx
Gi1/23              Desg FWD 20000     128.23   P2p Pre-STD-Rx
Gi1/33              Desg FWD 20000     128.33   P2p Pre-STD-Rx
Gi1/34              Desg FWD 20000     128.34   P2p Pre-STD-Rx
Gi1/41              Desg FWD 20000     128.41   P2p Pre-STD-Rx
Gi1/42              Desg FWD 20000     128.42   P2p Pre-STD-Rx
Gi1/43              Desg FWD 20000     128.43   P2p Pre-STD-Rx
Gi1/44              Desg FWD 20000     128.44   P2p Pre-STD-Rx
Gi1/45              Desg FWD 20000     128.45   P2p Pre-STD-Rx
Gi1/46              Desg FWD 20000     128.46   P2p Pre-STD-Rx
Gi2/1               Desg FWD 20000     128.257  P2p Pre-STD-Rx
Gi2/13              Desg FWD 20000     128.269  P2p Pre-STD-Rx
Gi2/29              Desg FWD 20000     128.285  P2p Pre-STD-Rx
Gi2/35              Desg FWD 20000     128.291  P2p Pre-STD-Rx
Gi2/36              Desg FWD 20000     128.292  P2p Pre-STD-Rx
Gi2/37              Desg FWD 20000     128.293  P2p Pre-STD-Rx
Gi2/38              Desg FWD 20000     128.294  P2p Pre-STD-Rx
Gi2/39              Desg FWD 20000     128.295  P2p Pre-STD-Rx
Gi2/40              Desg FWD 20000     128.296  P2p Pre-STD-Rx
Gi2/41              Desg FWD 20000     128.297  P2p Pre-STD-Rx
Gi2/42              Desg FWD 20000     128.298  P2p Pre-STD-Rx
Gi2/43              Desg FWD 20000     128.299  P2p Pre-STD-Rx
Gi2/44              Desg FWD 20000     128.300  P2p Pre-STD-Rx
Gi2/45              Desg FWD 20000     128.301  P2p Pre-STD-Rx
Gi2/46              Desg FWD 20000     128.302  P2p Pre-STD-Rx
Gi3/3               Desg FWD 20000     128.515  P2p Pre-STD-Rx
Gi3/15              Desg FWD 20000     128.527  P2p Pre-STD-Rx
Gi3/31              Desg FWD 20000     128.543  P2p Pre-STD-Rx
Gi3/39              Desg FWD 20000     128.551  P2p Pre-STD-Rx
Gi3/40              Desg FWD 20000     128.552  P2p Pre-STD-Rx
Gi3/41              Desg FWD 20000     128.553  P2p Pre-STD-Rx
Gi3/43              Desg FWD 20000     128.555  P2p Pre-STD-Rx
Gi7/5               Desg FWD 200000    128.1541 P2p Pre-STD-Rx
Gi7/6               Desg FWD 200000    128.1542 P2p Pre-STD-Rx
Gi7/11              Desg FWD 20000     128.1547 P2p
Po1                 Root FWD 10000     128.3329 P2p
------------------ show spanning-tree summary ------------------
Switch is in mst mode (IEEE Standard)
Root bridge for: none
EtherChannel misconfig guard is enabled
Extended system ID           is enabled
Portfast Default             is disabled
PortFast BPDU Guard Default  is disabled
Portfast BPDU Filter Default is disabled
Loopguard Default            is disabled
UplinkFast                   is disabled
BackboneFast                 is disabled
Pathcost method used         is long
Name                   Blocking Listening Learning Forwarding STP Active
MST0                         0         0        0        187        187
1 mst                        0         0        0        187        187
zhuch
Has anybody puzzled by the same problem?
