Cisco861 do not use IGMP Snooping
CSCO10993123
hi all,
I useing Cisco861  : C861-universalk9-mz.124-24.T3.bin
on my Cisco861 the command "ip pim dense-mode","ip igmp static-group "command does not exist,
router(config)# ip p?
port-map    prefix-list
router(config)#
router(config)# int vlan 1
router(config-if)# ip p?
policy   proxy-arp
router(config-if)#ip i?
idle-group   infomation-reply   inspect
router(config-if)#
but on the Cisco systems WEB-site
http://www.cisco.com/en/US/docs/routers/access/800/860-880-890/software/configuration/guide/vlanconf.html#wp1053218
Cisco861 use igmp command?
What am I missing??
i just a took a look at Cisco feature navigator and the 861 doesn't even appear in the platforms supporting PIM v2 nor IGMPv2.
Regards.
Alain
cadet alain
did you configure ip multicast-routing ? Furthermore ip pim dense-mode is an interface command.
if you don't have ip igmp static command you can use ip igmp join command which serves the same purpose.
Regards.
Alain
Hi, Alain
I want to configure multicast routing.
but my router is...
router(config)#int vlan 1
router(config-if)#ip p?
policy  proxy-arp
router(config)#int fastEthernet 1
router(config-if)#ip P?
% Unrecognized command
do not use  "ip pim dense-mode"command an interface command.
and,
router#
router#sh ip ig?
router#sh ip i?
icmp  inspect  interface
Did you mean......this kind of network configuration
cisco 861 is can not in multicast configuration?.
"MulticastServer"----"Cisco861"-------"Catalyst2940-8TT"-------"Multicast Receiver"
                               (querier)          (IGMP snooping)
Regards.
masayuki.
Regards.
Alain
HI,
Cisco 860, Cisco 880, and Cisco 890 Series Integrated Services Routers Software Configuration Guide
It is likely to mistake the cisco web site.
Try looking for a different platform can be used in IGMP.
Thanks.
Regards.
masayuki
