CISCO881GW and IPS
Pavel Pokorny
HI all,
I have problem to setup ips on my router.
License Information for 'c880-data'
    License Level: advsecurity_npe   Type: Permanent
System image file is "flash:c880data-universalk9_npe-mz.151-1.T1.bin"
But cannot follow :
http://www.cisco.com/en/US/prod/collateral/iosswrel/ps6537/ps6586/ps6634/prod_white_paper0900aecd805c4ea8.html
Step 4.1 is problem.
Router doesn't know the command : ip ips
Any advice will be appreciated.
Pavel
kmccourt
Looks like you have an Advanced Security licence. I'm pretty sure that you need Advanced IP Services to run IPS in this platform.  http://www.cisco.com/en/US/prod/collateral/routers/ps380/qa_c67_458826.html
I believe you also need a separate IPS subscription to update the IPS definitions.
kmccourt
Yes, you're right.
I've switched to advip, and command appeared.
What confuses me, is why advip?
I would expect IPS in security bundle, when it is security feature, more than ip service.....
But, thanks
Pavel
Advanced IP Services costs more - it has more features
esomarriba
Level 5
Level 5
Yes Adv Services is going to cost you more. With IOS 15 you have the option to try out the feature for up to 60 days, that gives you time to submit a PO and get the key, when you get the key you do not need to reboot the router! that's one nice feature of the new IOS platform.-
