class-map match-all or match-any: exact difference
ericgarnel
Level 7
Level 7
What is the exact difference between match-all & match-any?
http://www.cisco.com/en/US/products/hw/switches/ps708/products_command_reference_chapter09186a0080161029.html#wp1021242
it states the following:
class-map
To access the QoS class map configuration mode to configure QoS class maps, use the class-map command. To delete a class map, use the no form of this command.
class-map name [match-all | match-any]
no class-map name [match-all | match-any]
Syntax Description
name
Class map name.
match-all
(Optional) Matches all match criteria in the class map.
match-any
(Optional) Matches one or more match criteria.
Defaults
When you do not specify the match-all or match-any keyword, the default is match-all.
So, if I have 6 match lines under my class, would match-any & match-all behave the same?
The definition seems very vague to me
Eric
Pavel Bykov
Level 5
Level 5
Hello.
In Match-any:
Any one line has to match for match to occur.
In Match-all:
ALL lines have to match for match to occur.
I.E.:
1.
class-map match-all ABC
match access-group 10
match access-group 20
--In this case packet has to match both ACL 10 AND ACL 20
2.
class-map match-any ABC
--In this case packet has to match AT LEAST one access list.
Hope this helps.
Please rate if it does.
6 Replies 6
Pavel Bykov
Level 5
Level 5
Hello.
In Match-any:
In Match-all:
I.E.:
1.
2.
Hope this helps.
Thanks, That is a clearer explanation
ankbhasi
Hi Eric,
If you have 6 statements under your class and you have "match all" keyword selected than class map will be triggered only if all statements hold true so for class to come in action all 6 statements/conditions should match and if you have selected "match any" keyword then any of the statement hold true out of 6, class map will trigger.
Ankur
Hi, one question, What's the recommendation to use, Match-any or Match-all?
Thanks for your comments.
Strictly depends on your match requirements logic.
Effectively "any" is a logical "or" between match statements while an "all" is a logical "and".
patkszen
I guess another way of configuring this would be to have an ACL with multiple permit or/and deny rules and use match-all for your class-map. All depends on your requirements.
