class-map voice-priority
saidfrh
We are replacing a router. I saw the following lines in the config. Can someone clarify what the following are for?
1. priority 512
2. why are there TCP ports for mapping voice packets?
match access-group 150
policy-map POLICY1
class voice-priority
priority 512
class class-default
fair-queue
access-list 150 permit udp any any range 5000 5070
access-list 150 permit udp any range 5000 5070 any
access-list 150 permit udp any any eq 5567
access-list 150 permit udp any eq 5567 any
access-list 150 permit tcp any any eq 5566
access-list 150 permit tcp any eq 5566 any
access-list 150 permit tcp any any eq 5570
access-list 150 permit tcp any eq 5570 any
access-list 150 permit udp any any eq 16384
access-list 150 permit udp any eq 16384 any
access-list 150 permit tcp any any eq 2427
access-list 150 permit tcp any eq 2427 any
access-list 150 permit udp any any eq 4000
access-list 150 permit udp any eq 4000 any
access-list 150 permit udp any any eq 4010
access-list 150 permit udp any eq 4010 any
ajagadee
Said,
Priority 512 is basically having the router dedicate 512K for the traffic matching the class voice-priority. In your case, all traffic that matches access-list 150. And if I remember correctly, I think TCP Port 5566 is used for call signaling.
You can look at the access-list counters to see if the phones are using those TCP ports or not. Just a thought.
Arul
** Please rate all helpful posts **
