Class-Maps show numbers instead of ACL names...
vbuendia
I just configured a few policers for a Catalyst 3560 and when reviewing the configuration, I found that the Class-Maps show numbers instead of ACL names when showing the config or the class-maps themselves. I am running 12.2(25)SEE and I had never seen this before. I wonder if anyone has any information related to this.
Below is the example of the output, as you can see, the access-lists are defined but now I cannot co-relate the names with the class maps.
show run
class-map match-any LRC-QOS-ORACLE
match access-group name 825374768
class-map match-any LRC-QOS-EXCHANGE
class-map match-any LRC-QOS-AUTHENTICATION
class-map match-any LRC-QOS-AD
class-map match-any LRC-QOS-SQL-OASIS
class-map match-any LRC-QOS-VOICE-SIGNALING
class-map match-any LRC-QOS-DS-DHCP
class-map match-any LRC-QOS-VIDEO
class-map match-any LRC-QOS-SCAVENGER
class-map match-any LRC-QOS-SQL-F&B
class-map match-any LRC-QOS-RDP
ip access-list extended LRC-QOS-AD
permit ip host 172.16.0.17 any
permit ip host 172.16.0.23 any
permit ip host 172.16.16.2 any
permit ip any host 172.16.0.17
permit ip any host 172.16.0.23
permit ip any host 172.16.16.2
ip access-list extended LRC-QOS-AUTHENTICATION
permit ip host 172.16.0.84 any
permit ip any host 172.16.0.84
!The rest of the ACLs have been suppressed due to space limitations
end
CAT-3560#
CAT-3560#show class-map
Class Map match-any LRC-QOS-ORACLE (id 1)
Match access-group name 1280459565
Class Map match-any LRC-QOS-EXCHANGE (id 2)
Class Map match-any LRC-QOS-AUTHENTICATION (id 3)
Class Map match-any LRC-QOS-AD (id 4)
Class Map match-any class-default (id 0)
Match any
Class Map match-any LRC-QOS-SQL-OASIS (id 5)
Class Map match-any LRC-QOS-VOICE-SIGNALING (id 6)
Class Map match-any LRC-QOS-DS-DHCP (id 7)
Class Map match-any LRC-QOS-VIDEO (id 8)
Class Map match-any LRC-QOS-VOICE (id 9)
Class Map match-any LRC-QOS-SCAVENGER (id 10)
Class Map match-any LRC-QOS-SQL-F&B (id 11)
Class Map match-any LRC-QOS-RDP (id 12)
Class Map match-any LRC-QOS-SQL (id 13)
Edison Ortiz
I was able to duplicate it on 12.2(25)SEE4 (which is the latest code on that train).
I don't see the problem on 12.2(25)SED1, try that release.
It seems to be a bug.
Edison Ortiz
That did it Edison. Thanks for replying.
