Clear counter in Nexus 5K
johnlloyd_13
Level 9
Level 9
hi all,
just a quick one, i tried to issue a 'clear counter et1/x' on our nexus 5k switch but got an error saying it's part of a port-channel.
tried to clear it using port-channel interface but can't. my question is, how do you issue a clear counter int x on a nexus switch?
2 Accepted Solutions
Dinesh Sharma
I think x port belong to Channel Group.
Drew Browning
I just ran the following command on my 5k and it worked just fine.  It is also a part of a VPC so I am not really sure what you the issue is on your switch.
clear counters interface port-channel X
Dinesh Sharma
Drew Browning
hi,
thanks! i did a 'clear counters' last time.
i'm trying to get used to nexus OS.
# sh int e1/1 | i err
    27 input error  0 short frame  0 overrun   0 underrun  0 ignored
    0 output error  0 collision  0 deferred  0 late collision
# clear counters interface e1/1
Ethernet1/1 is member of port-channel105.
Clearing counters for physical port(s) which is/are part of a port-channel will cause inconsistency in statistics. Thus operation for those port(s) is skipped.
# sh port-channel summary
Flags:  D - Down        P - Up in port-channel (members)
        I - Individual  H - Hot-standby (LACP only)
        s - Suspended   r - Module-removed
        S - Switched    R - Routed
        U - Up (port-channel)
        M - Not in use. Min-links not met
Group Port-       Type     Protocol  Member Ports
      Channel
12    Po12(SU)    Eth      LACP      Eth1/22(P)   Eth1/23(P)
103   Po103(SD)   Eth      LACP      Eth1/17(D)
104   Po104(SD)   Eth      LACP      Eth1/19(D)
105   Po105(SU)   Eth      LACP      Eth1/1(P)
106   Po106(SU)   Eth      LACP      Eth1/2(P)
107   Po107(SU)   Eth      LACP      Eth1/3(P)
108   Po108(SU)   Eth      LACP      Eth1/4(P)
# clear counters interface port-channel 105
    0 input error  0 short frame  0 overrun   0 underrun  0 ignored
mdsk0905
Po10 Eth LACP Eth1/10 Eth1/20
Po11 Eth LACP Eth1/11 Eth1/21
# sh int port-channel 10
11250 input error
CLEAR COUNTER (Errors)
# clear counters int port-channel 10
RESULT: 0 input error
