Clear xlate on Catalyst 3750
Robert Hefner
Hey folks,
I am trying to clear the xlate table from a Catalyst 3750. The command below is not available to me via the CLI. Has the command changed?
clear xlate
Tried in both modes.
Thanks - Robert
as far as I recall, this is a command on the ASA, are you sure it is supposed to be on the 3750 ?
3750 does not support NAT:
https://www.cisco.com/c/en/us/support/docs/ip/network-address-translation-nat/29283-166.html
-If I helped you somehow, please, rate it as useful.-
As it was mentioned by other members, xlate is used on ASA firewall and NAT is not supported on this switch model.
Now if you are looking for the command for any router it is: clear ip nat translation *
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
