Clearing DSL Stats
danny9797
I'm wondering how to clear the counters on DSL stats (reed-solomon, crc, header errors), etc? I thought the clear counters command on the atm interface would clear them but they do not.
owillins
Level 6
Level 6
clear counters [type slot/port]
This command clears all the current interface counters from the interface unless you specify the optional arguments type and number to clear only a specific interface type (serial, Ethernet, Token Ring, and so on).
