CLI command
nerraw774
Community Member
What command can I use to view who log into a switch.
jdamon113
Community Member
sh users
As jdamon113 says, the show users command will tell you which users are currently logged in, including the user running the command indicated with an asterisk (*).
c1kv-1#sh users
    Line       User       Host(s)              Idle       Location
   1 vty 0     admin      idle                 00:02:27 192.168.1.78
*  2 vty 1     admin      idle                 00:00:09 192.168.1.78
It's not clear from the question, but if you need to know which user has logged in / out and when, you can use the login on-success and login on-failure commands to generate a SYSLOG message. These commands were added as part of the Cisco IOS Login Enhancements.
These are the commands in the configuration:
c1kv-1# sh run | in ^login
login on-failure log
login on-success log
And these are the SYSLOG messages generated:
*Sep  6 16:32:56.188: %SEC_LOGIN-5-LOGIN_SUCCESS: Login Success [user: admin] [Source: 192.168.1.78] [localport: 22] at 16:32:56 UTC Sun Sep 6 2015
*Sep  6 16:33:21.346: %SYS-6-LOGOUT: User admin has exited tty session 1(192.168.1.78)
*Sep  6 16:33:30.353: %SEC_LOGIN-4-LOGIN_FAILED: Login failed [user: admin] [Source: 192.168.1.78] [localport: 22] [Reason: Login Authentication Failed] at 16:13:30 UTC Sun Sep 6 2015
Thank you for your response.
