Client loses randomly Connectivity
MarioLieb
Level 3
Level 3
Hi @Aliki
since some week´s we have a strange error and no one can told me a sollution. So i will ask here 😉
I have Clients, Win 7 and Win 10 which losses randomly Network Connectivty. The LAN- Icon at the Client show the yellow exclamation mark. No communication can be done. Switch 2960x show no log the port is all the time up. Wireshark show no error, broadcaststrom an so on ...
It seems that the client will have an IP- Adresse DNS- Server and so on but can not resolve the names ...
Did anyone hear about that problem.
Stack
Switch Ports Model SW Version SW Image
* 1 52 WS-C2960X-48LPS-L 15.2(2)E7 C2960X-UNIVERSALK9-M
2 52 WS-C2960X-48LPS-L 15.2(2)E7 C2960X-UNIVERSALK9-M
3 52 WS-C2960X-48LPS-L 15.2(2)E7 C2960X-UNIVERSALK9-M
Port Config
interface GigabitEthernet3/0/2
network-policy 1
switchport access vlan xxx
switchport mode access
switchport port-security maximum 3
switchport port-security aging time 3
srr-queue bandwidth share 1 80 10 15
srr-queue bandwidth shape 2 0 0 0
priority-queue out
no snmp trap link-status
mls qos trust dscp
storm-control broadcast level pps 500 300
storm-control multicast level pps 500 300
storm-control action shutdown
spanning-tree portfast
service-policy input PM-AccessPort_policed-dscp-transmit
end
Regards Mario
15 Replies 15
Reza Sharifi
For testing purpose, have you tried a port without security, QOS and storm control configs and watch for the same behavior?
Hi Reza
no. But i will do that now 😉
 network-policy 1
 priority-queue out
end
Georg Pauwen
on a side note, this could be a NIC problem as well, try to un- and reinstall the drivers for the NIC on the 'problem' PCs. Also, do you have any antivirus software running on the clients ?
Does the event viewer in Windows show anything ?
the eventlog show nothing … i also made a test and disabled Stormcontrol at this port.
This also dosn´t help ...
At the Moment i test QoS Settings … but i am not sure this will solve the Problem.
hankr3ard3n
Community Member
Mario,
Did you ever have a solution to this problem?  I am having the same issue after upgrading to 2960X switches....
Hi Hank
i don´t have solved the problem. But i have a workaround. We removed the settings
after i removed this setting all works fine. I think this is a IOS- BUG. Forthat issue i will also open a TAC
Hi @MarioLieb,
your switch had found 3 differents MAC Address and that's why the port maybe got blocked, you can validate that using the next command:
show interfaces status | i err
and
show port-security interface [INTERFACE]
If your problem got a solution, please mark as solved. If you think that the commands I gave you are helpful, please mark as Helpful,
Hi Pedro
nice try that is not my problem the Port is NOT err- Dis and the port is always UP. The problem is that the Client shows limited Connectivity. The LAN- Icon shows a yellow exclamation mark. Same config on a 2960S works on a 2960X there are this Problems. Seems to by a similar bug like CSCve53124 or CSCue23882 but not 100 % the same.
Regard Mario
MarioLieb,
Did you try upgrading IOS versions as suggested in CSCve53124 ??
We are trying this now...
Hi Hank
no i don´t try this. we use the iOS
*    2 52    WS-C2960X-48LPS-L         15.2(2)E7             C2960X-UNIVERSALK9-M
Please let me know if your try is working 😉
THX
Hi Hank
i tested the IOS 15.2(2)E9 with Port- Security … same error. I will now open a TAC. .Hope this will be help.
Regards Mario
Please download and install IOS 15.2(6)E2 or higher... so far we have had
good results ( more than 1 week no issues)...
@all short information i think @hankr3ard3n is right. Since update to
     1 54    WS-C2960X-48LPS-L         15.2(6)E2             C2960X-UNIVERSALK9-M
*    2 54    WS-C2960X-48LPS-L         15.2(6)E2             C2960X-UNIVERSALK9-M
     3 54    WS-C2960X-48LPS-L         15.2(6)E2             C2960X-UNIVERSALK9-M
we don´t have any issues since two weeks. So i think the solution is to update to mentioned IOS.
Regards Mario
I have same problem but on 3650 version Cisco IOS Software [Everest], Catalyst L3 Switch Software (CAT3K_CAA-UNIVERSALK9-M), Version 16.6.6, RELEASE SOFTWARE (fc1)
