Clock setting won't stick
csisadmin
Community Member
I have a Catalyst 3550 that won't keep it's clock setting. Notice below, that when I set it, there is a dot pre-pended to the time. None of the other switches have this.
cat3550p#clock set 18:42:00 Mar 12 2005
cat3550p#sho clock
.18:42:05.379 EST Sat Mar 12 2005
When I reload the switch, it will go back to a 1993 date. Does anyone know how to fix this?
Thanx,
Mary
alagrawa
Level 6
Level 6
Hi Mary,
Thanks for writing in. The cat3550 does not have a hardware clock, therefore when it is powered off and back on, the clock gets reset back to 1993.
The workaround is to use NTP in your network.
http://www.cisco.com/univercd/cc/td/doc/product/lan/c3550/12225se/3550scg/swadmin.htm#wp1020799
Hope that helps
regards
-Alok
