Cluster Command Switch prompt
sivaprakasam81
Level 5
Level 5
Hi All,
why do we use Cluster Command Switch prompt?
Thank you,
Leo Laohoo
If you are talking about switch clustering, then it's usefull to "manage" a stack of switches with only ONE IP Address.
This is very useful if someone deployed a switch, out of the box, and into a remote site without even configuring the IP Address and the correct port details.
This helped me alot, much to my colleagues chagrin.
Thank you so much. I need to perform the same activity. Can you please provide me the resource. If possible any link which has info about Switch clustering. So that i can manage stack of switches remotely.
Thanking you,
Siva
Thanks for the rating.
Here's the configuration example for Switch Clustering.
http://www.cisco.com/en/US/docs/switches/lan/catalyst2900xl_3500xl/releasesa6/scg/kiclust.html
Hope this helps.
