CNA Span\Monitoring option
radioflyer1
I would like to setup monitoring on a port for packet sniffing and I would like to use the CNA software. The issue is I can't seem to find the option. I believe it should be listed under the menu...Configure\Switching but it is not there. I am runing CNA version 5.6 (3) on a 4510R-E. Is this possible via CNA or do I need to do it from the command line?
Thanks!
Amit Aneja
Level 3
Level 3
The 4500 series switch does not support SPAN feature through the CNA application. In order
to do that, the you would need to do it using CLI.
Take a look at the features that are supported by 4500 using CNA in the link below.
http://www.cisco.com/en/US/docs/net_mgmt/cisco_network_assistant/version5_0/release/notes/OL12210a.html#wp772124
On the switches where it is supported, you will find this option under switching in the configuration tab you should be seen SPAN option in there.
CLI reference to configure SPAN:
http://www.cisco.com/en/US/customer/docs/switches/lan/catalyst4500/12.2/31sga/configuration/guide/span.html#wp1043935
Amit
Thanks Amit! I appreciate the guidence.
Ry
Glad, I could help.
Please mark the post as answered if you do not have any follow up questions.
