collision detection
eng.yanev
Hi, I have developed a Ethernet network of 100 computers, how to explore the collisions in the same network with Packet Tracer6. Thank you in advance.
Jon Marshall
"sh interface <int>" will show you the collisions per interface.
Note that if you are using switches to connect up your devices and you are running the ports in full duplex you should not see any collisions.
Jon
Thanks i use a half duplex network but where am I supposed to write this command using switch command-line interface (CLI) or something else?
