Collisions & late collisions on fibre port
Andy White
Level 3
Level 3
I am trying to see if a fibre port is at fault here, basically a user is complaining a file being transfered through this fibre link is gettign corrupted, but from the stats below they look ok to me.  There seems to be late collisions and collisions (this port has had it's counters reset 2 hours ago), but I'm not sure if that is how fibre works, but I would be concerned on copper, but this is half duplex so I guess it has to happen.
CRCs are good and reliability is 255/255 so maybe it is their software creating the corruption, maybe you can see somethign I can't.
show int gig 2/0/5 transceiver properties
Diagnostic Monitoring is not implemented.
Administrative Speed: auto
Administrative Duplex: auto
Administrative Auto-MDIX: on
Administrative Power Inline: N/A
Operational Speed: 100
Operational Duplex: half
Operational Auto-MDIX: on
Media Type: 100BaseFX SFP
show udld gigabitEthernet 2/0/5
Interface Gi2/0/5
Port enable administrative configuration setting: Follows device default
Port enable operational state: Enabled / in aggressive mode
Current bidirectional state: Unknown
Current operational state: Advertisement
Message interval: 7
Time out interval: 5
No neighbor cache information stored
show int gig 2/0/5 controller
GigabitEthernet2/0/5 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is 0019.0691.0d05 (bia 0019.0691.0d05)
  Description: LCD
  MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
  Keepalive not set
Half-duplex, 100Mb/s, link type is auto, media type is 100BaseFX SFP
  input flow-control is off, output flow-control is unsupported
  Last input 10w4d, output 00:00:47, output hang never
  Last clearing of "show interface" counters 01:39:49
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute input rate 61000 bits/sec, 59 packets/sec
  5 minute output rate 60000 bits/sec, 60 packets/sec
     255318 packets input, 37292610 bytes, 0 no buffer
     Received 11620 broadcasts (48 multicasts)
     0 watchdog, 48 multicast, 0 pause input
     471123 packets output, 68775081 bytes, 0 underruns
     0 output errors, 650 collisions, 0 interface resets
     0 babbles, 421 late collision, 0 deferred
     Transmit GigabitEthernet2/0/5            Receive
   2724666016 Bytes                       1896707999 Bytes
      2537751 Unicast frames                 2450415 Unicast frames
     11948801 Multicast frames              15806197 Multicast frames
     11876703 Broadcast frames                410331 Broadcast frames
            0 Too old frames               360602656 Unicast bytes
       307571 Deferred frames             1422491352 Multicast bytes
            0 MTU exceeded frames           39713108 Broadcast bytes
         8814 1 collision frames                   0 Alignment errors
        90958 2 collision frames                   0 FCS errors
        46096 3 collision frames                   0 Oversize frames
         8108 4 collision frames                   0 Undersize frames
          586 5 collision frames              355951 Collision fragments
           37 6 collision frames
            6 7 collision frames              648167 Minimum size frames
            5 8 collision frames            17097347 65 to 127 byte frames
           40 9 collision frames              484522 128 to 255 byte frames
           64 10 collision frames             415528 256 to 511 byte frames
           11 11 collision frames              10835 512 to 1023 byte frames
            3 12 collision frames              10544 1024 to 1518 byte frames
            0 13 collision frames                  0 Overrun frames
            0 14 collision frames                  0 Pause frames
            0 15 collision frames
            0 Excessive collisions                 0 Symbol error frames
        37182 Late collisions                      0 Invalid frames, too large
            0 VLAN discard frames                  0 Valid frames, too large
            0 Excess defer frames             355951 Invalid frames, too small
      3669112 64 byte frames                       0 Valid frames, too small
     21772140 127 byte frames
       496964 255 byte frames                      0 Too old frames
       276724 511 byte frames                      0 Valid oversize frames
        31195 1023 byte frames                     0 System FCS error frames
       153333 1518 byte frames                     0 RxPortFifoFull drop frame
            0 Too large frames
         8814 Good (1 coll) frames
       145914 Good (>1 coll) frames
glen.grant
  The links if they are fiber should not be at half duplex and should be corrected.   Both ends should be set to full duplex.
Seems the remote device is a screen of some sort that is only able to run half duplex, I guess this is the reason for the collisions and late collisions?
  Yes any port that is half duplex will have collisions, normal part of half duplex operation .
