Command for IOS 3945 E
silviorodrigues
Level 2
Level 2
Dears My vendor recomend for my equipment Cisco Router 3945 E the IOS SL-39-DATA-K9, but I don´t if it accept this command below!
Follow a exemplo:
conf t
     ip vrf XXXX
          rd XXXX:YY
          route-import XXXX:YY
          route-export XXXX:YY
     mpls label protocol ldp
     no mpls ip propagate-ttl
     no mpls ldp advertise-labels
     mpls ldp advertise-labels for MPLS-TAG-LOOPBACKS to LDP-NEIGHBORS
     interface Port-channel1.2
           description DMZ - Routers
           encapsulation dot1Q 2
           ip address 189.90.0.1 255.255.255.0
           ip broadcast-address 189.90.0.255
           ip flow ingress
           mpls mtu 1600
           mpls ip
          ip router isis
          clns router isis
          standby 21 ip X.X.X.X
     ip router isis
           net 49.XXXX.XXXX.XXXX.XXXX.00
           is-type level-2-only
           metric-style wide
           log-adjacency-changes all
           mpls traffic-eng router-id Loopback20
           exit
     ip router bgp XXXX
          address-family ipv4
          address-family ipv4 vrf XXX
          address-family vpnv4
Thanks for your help!
Tareq Rajabi
Community Member
Hi there,
you have the 3945 with the data package (39-Data-K9). You should be able to put in those commands without a problem.
You can check out
http://www.cisco.com/en/US/prod/collateral/iosswrel/ps8802/ps5460/product_bulletin_c25-566278_ps10538_Products_Bulletin.html to see what comes with the data package (picture is very helpful!)
