command for module finding
networking11
Level 3
Level 3
Hi all,
can u help me for the required commands in finding the following modules
MEM-MSFC2-512MB
MEM-XCEF720-512MB
Anand
passioncas
Level 3
Level 3
Hi Anand,
Try Show Module or Show Hardware commmands
Yudong Wu
Level 11
Level 11
Those are memory part number. There is no command to find them.
In general, you need find out memory size of MSFC, DFC, or CFC and then you can go to the "memory upgrade guide" to find the part number.
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat6000/cfgnotes/index.htm
Or look it up in data sheet.
