Command information :no dss interface-purge
dominic.caron
Level 11
Level 11
I've got this in the default config of a new 6500 VSS. Can someone tell me what it is?
no dss range-purge
no dss mac-purge
dfedotovs
Frequent Visitor
Frequent Visitor
Dominic,
Sorry to bump the old thread but your entry was the only one I've found.
I have observed that this set of commands is enabled after disabling Netflow on the 6500 switch PFC with "no mls netflow".
I wasn't able to find any information on these commands and impact of them. Did you have any luck with this?
Dmitri
