Command to check for logging level
RMS3
Level 3
Level 3
I have enabled logging on C9200 switch with logging level 6.
Is there a show command to check the logging level?
DanielP211
Yes. you can check the level if you input show logging. Then under Console logging/monitor logging/buffer logging the levels are displayed:
Console logging: level informational, 18106 messages logged, xml disabled,
filtering disabled
Monitor logging: level debugging, 0 messages logged, xml disabled,
filtering disabled
Buffer logging: level debugging, 2489 messages logged, xml disabled,
filtering disabled,
BR
****Kindly rate all useful posts*****
Mark Elsen
         - FYI : show run | inc logging
 M.
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
Thanks for the response.
The output of show run | include logging is
logging trap syslog-format rfc5424
logging host x.x.x.x
This does not show the level of logging (in my case level 6).
I would need to check this. Any suggestions?
DanielP211
filtering disabled
filtering disabled
filtering disabled,
BR
