Campus Upgrade from 6800 Collapsed Core with 3850 Access to 9504 as CO
Ibrahim Jamil
Level 6
Level 6
Hi Freinds
I have an upgrade project in my hands
Current Campus based on 6800 Collapsed Core with 3850 Access ( where the PC /IP Phone/AP are connected ) in STP-based
we need to upgrade to 9504 as CORE with 9300 PoE + as Access with a VxLAN topology , so how the  PC /IP Phone/AP behind 9300 PoE + behave
Pls Advise for optimal Design as per the Above input
Thanks all
7 Replies 7
balaji.bandi
There is no differernce when you Migrating to new Topolgy
is the new Topology is SD-Acess or traditional - if traditionla why are you using VXLAN ?
VXLAN is part of Fabric, this is nothing to do with end  device  PC / Phone and AP - they work as expected.
Only changes if you looking SD-Access - Anycast gateway
But you need to consider how your Migration approach - read below guide :
https://community.cisco.com/kxiwq67737/attachments/kxiwq67737/5981-discussions-other-network-infra/197124/1/Cisco%20Software%20Defined%20Access%20Migration%20Guide.pdf
There is good reference start with :
https://www.ciscolive.com/c/dam/r/ciscolive/emea/docs/2020/pdf/R6BGArNQ/TECCRS-2812.pdf
BB
Leo Laohoo
That is nothing but a layer 2 network and upgrading to a 9500 and 9300 is really overkill/OTT (over the top).  I could get away with a 9300X as core switch (for fibre) and a Catalyst 1000 as an access switch.
Ibrahim Jamil
Level 6
Level 6
Hello Freinds
seems 9300 poe+ didn't support VxLAN :((((
Need to  get rid of STP from Access to CORE , need all links FW
Not sure where this statement come from - you need to give full model of the switch and what License you have on the switch.,
below License guide :
BB
Ibrahim Jamil
Level 6
Level 6
Hello my freind
its C9300-48P with DNA Lic Adv , pls not we are not going to run SDA
You mean to say you are having License of DNA Advantage, not necessary you need to run DNAC and SD-Accesss - that is License you purchased.
BB
Ibrahim Jamil
Level 6
Level 6
Hello My Frerind Balagi
does the below Model support VxLAN
