Communication between a wired host and a wireless host
sebas1234
Hello, I have this topology. When I ping from the Laptop to PC it works, but when I try to ping from the PC to the Laptop it doesn't work, why does this happen?
I see what you mean...that is a limitation (bug) in Packet Tracer. The wireless routers allow for unidirectional (LAN to Internet) communication only.
6 Replies 6
Why this happens? Because something is wrong here. But it is impossible to tell without any information.
I would start troubleshooting by looking at the Laptop if the Firewall is enabled and blocking the ping.
post the zipped Packet Tracer project (.pkt) file...
Do you have the file ?
That's the file
