Communication between two different network of two location
Imran Mohammad
Hi All,
We have two sites one is having Public IP (static) by ISP assigned in gateway: 61.12.26.68  and its LAN Network 172.168.10.x  SM: 255.255.252.0. another site having Public IP (static) by ISP assigned in gateway: 111.93.124.160 and its LAN network is 192.168.10.x SM: 255.255.252.0
How can we communicate their local network of two different location over the internet ?
Please answer, looking your earliest help. Thanks !
Md Imran
Mark Malone
Build a lan - lan IPsec tunnel that's one option easily  done between the 2 public interfaces
2 easy guides to follow
http://www.cisco.com/c/en/us/support/docs/routers/1700-series-modular-access-routers/71462-rtr-l2l-ipsec-split.html
Joseph W. Doherty
There are two ways.
You could NAT both sites and route between them using the other site's NAT addresses.  This approach would be difficult unless you have a number of public IPs for each site's host that corresponds to the hosts you want to reach externally.
Or you could build a VPN tunnel between the sites.
cofee
Level 5
Level 5
You should have ip reachability between these two sites as they are connected to the Internet. You can build a gre tunnel between the sites and use IPSec for security. This will give you the ability to route traffic between the sites over the gre tunnel.
