compabilty question
jryzhkov1
Visitor
Доброго дня!
I've got this Catalyst:
WS-C3850-24XS-E
Cisco Catalyst 3850 24 Port 10G Fiber Switch IP Services
CON-SNT-WS850XSE
SNTC-8X5XNBD Cisco Catalyst 3850 24 Port 10G Fiber Sw (support/Smarnet)
PWR-C1-715WAC/2
715W AC Config 1 Secondary Power Supply
CAB-TA-EU
Europe AC Type A Power Cable
STACK-T1-50CM
50CM Type 1 Stacking Cable
CAB-SPWR-30CM
Catalyst 3750X and 3850 Stack Power Cable 30
C3850-NM-BLANK
Cisco Catalyst 3850 Network Module Blank
SFP-10G-LR-S+
10GBASE-LR SFP Module, Enterprise-Class
PWR-C1-715WAC
715W AC Config 1 Power Supply
GLC-TE=
1000BASE-T SFP
S3850UK9-37E
CAT3850 Universal k9 image
On the other site this thing:
HPE 6125XLG Ethernet Blade Switch
711307-B21
Question is can I connect them with this cable:
HPE FlexNetwork X240 10G SFP+ to SFP+ 0.65m Direct Attach Copper Cable
JD095C
Or with this trancivers:
HPE X130 10G SFP+ LC LR Transceiver JD094B----SFP-10G-LR-S=
Thanks in advance!
Mark Malone
cant comment on HP but here is what the Cisco switch supports exactly 1 and 10gb
Catalyst 3850 series
Network Device
Transceiver Model
Minimum Software Release Required
DOM Support
Software Release
WS-C3850-12XS
WS-C3850-16XS
WS-C3850-24XS
WS-C3850-32XS
(with C3850-NM-8-10G NM)
GLC-T (10/100/1000)
GLC-TE
GLC-LH-SM
GLC-LH-SMD
GLC-SX-MM
GLC-SX-MMD
GLC-EX-SMD1
GLC-ZX-SM
GLC-ZX-SMD
GLC-BX-D
GLC-BX-U
CWDM SFP
SFP-GE-S
SFP-GE-L
SFP-GE-T
SFP-GE-Z
DWDM SFP
DWDM SFP (add.)
GLC-BX40-D-I
GLC-BX40-DA-I
GLC-BX40-U-I
GLC-BX80-D-I
GLC-BX80-U-I
XE 3.7.1
XE 3.7.1
WS-C3850-12XS
WS-C3850-16XS
WS-C3850-24XS
WS-C3850-32XS
(C3850-NM-8-10G uplink modules)
SFP-10G-SR
SFP-10G-LRM
SFP-10G-LR
SFP-10G-ER
SFP-10G-ZR
SFP-10G-SR-S
SFP-10G-LR-S
SFP-10G-ER-S
SFP-10G-ZR-S
DWDM SFP+
CWDM SFP+
SFP-H10GB-CU1M
SFP-H10GB-CU1-5M
SFP-H10GB-CU2M
SFP-H10GB-CU2-5M
SFP-H10GB-CU3M
SFP-H10GB-CU5M
SFP-H10GB-ACU7M
SFP-H10GB-ACU10M
SFP-10G-AOC1M
SFP-10G-AOC2M
SFP-10G-AOC3M
SFP-10G-AOC5M
SFP-10G-AOC7M
SFP-10G-AOC10M
SFP-10G-BXD-I
SFP-10G-BXU-I
SFP-10G-BX40D-I
SFP-10G-BX40U-I
XE 3.7.1E
XE 3.7.1E
