Compare IOS-XE Versions
tcebak
Level 2
Level 2
-Is there a tool that can compare two different versions of IOS-XE versions? I just want to know major features allowed or removed.
I know the release notes contain that information but it doesn't cover what's changed if you're coming from an older version. For example i know from 16.6.5 to 16.12.03a you can now support object groups to make cleaner ACL's. But if you view 16.12.03a you don't really see that listed.
Also, Cisco Feature Navigator only has 3 versions listed for the cat 9300.
Basically just want to see a majority of the differences between IOS-XE 16.6.5 to 16.12.03a on the Catalyst 9300.
Leo Laohoo
