conditional config in cisco switch 2960
hamideghbalian
hi all , i want to config cisco switch as if the port is trunk some situation is met (what i want), otherwise (port is access) some other sitution is met.
for example if the port is access just config sw por max 1 and if the port is trunk just sw mode trunk encapluation dot.1q...
ane ideas?
i want for group config switches
5 Replies 5
config two template,
config one template under access port
config other template under trunk port
I have a lot of switches.And I want to configure all the ports as a group. And I want it to be checked before the configuration, what configuration to use if it was an access port and what configuration to use if it was a trunk port.
IOU1#show run
IOU1#show running-config '
% Invalid input detected at '^' marker.
Building configuration...
Current configuration : 1972 bytes
! Last configuration change at 15:13:45 UTC Sat Jul 8 2023
version 15.2
service compress-config
hostname IOU1
boot-start-marker
boot-end-marker
logging discriminator EXCESS severity drops 6 msg-body drops EXCESSCOLL
logging buffered 50000
logging console discriminator EXCESS
no aaa new-model
no ip icmp rate-limit unreachable
no ip domain-lookup
ip cef
no ipv6 cef
spanning-tree mode rapid-pvst
vlan internal allocation policy ascending
ip tcp synwait-time 5
template trunk1
switchport trunk allowed vlan 10,20
switchport mode trunk
template trunk2
switchport trunk allowed vlan 30,40
template vlan10
switchport access vlan 10
template vlan20
switchport access vlan 20
interface Ethernet0/0
source template vlan10
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet1/0
source template vlan20
interface Ethernet1/1
interface Ethernet1/2
interface Ethernet1/3
interface Ethernet2/0
source template trunk1
interface Ethernet2/1
interface Ethernet2/2
interface Ethernet2/3
interface Ethernet3/0
interface Ethernet3/1
interface Ethernet3/2
interface Ethernet3/3
interface Vlan1
no ip address
shutdown
ip forward-protocol nd
no ip http server
no ip http secure-server
control-plane
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
line vty 0 4
login
below simple lab, it easy to use template,
please careful when config trunk template, any misconfig will lead to L2 LOOP.
double check before apply template for trunk
M02@rt37
Hello @hamideghbalian
depend of your IOS release, you should have this:
https://content.cisco.com/chapter.sjs?uri=/searchable/chapter/content/en/us/td/docs/ios-xml/ios/ibns/configuration/15-e/ibns-15-e-book/ibns-int-temp.html.xml
Best regards
