Question about MST and PVST
danielrattee
This question builds off of the following post:
https://community.cisco.com/t5/switching/inconsitent-inferior-pvst-bpdu-received-on-vlan-10/td-p/4852991
Would moving the MST switch (sw-50) to PVST to match (SW-03) resolve the issues in the linked post?
17 Replies 17
Still this issue not solved?
Can I see show spanning tree interface x/x
SW-050#show spanning-tree
MST0
Spanning tree enabled protocol mstp
Root ID Priority 32768
Address 0027.XXXX.a500
This bridge is the root
Hello Time 2 sec Max Age 20 sec Forward Delay 15 sec
Bridge ID Priority 32768 (priority 32768 sys-id-ext 0)
Interface Role Sts Cost Prio.Nbr Type
Gi1/0/1 Desg FWD 20000 128.1 P2p
Gi1/0/2 Desg FWD 200000 128.2 P2p Edge
Gi1/0/6 Desg FWD 200000 128.6 P2p Edge
Gi1/0/8 Desg FWD 20000 128.8 P2p Edge
Gi1/0/10 Desg FWD 20000 128.10 P2p Edge
Gi1/0/11 Desg FWD 20000 128.11 P2p Edge
Gi1/0/13 Desg FWD 20000 128.13 P2p Edge
Gi1/0/15 Desg FWD 20000 128.15 P2p Edge
Gi1/0/17 Desg FWD 20000 128.17 P2p Edge
Gi1/0/20 Desg FWD 20000 128.20 P2p Edge
Gi1/0/22 Desg FWD 20000 128.22 P2p Edge
Gi1/0/23 Desg FWD 20000 128.23 P2p Edge
SW-03
VLAN0010
Spanning tree enabled protocol rstp
Root ID Priority 4106
Address c4b3.YYYY.d480
Cost 1
Port 3049 (Port-channel1)
Bridge ID Priority 8202 (priority 8192 sys-id-ext 10)
Address acf5.YYYY.7b80
Aging Time 300 sec
Tw1/0/17 Desg FWD 19 128.17 P2p Edge
Tw1/0/19 Desg FWD 19 128.19 P2p Edge
Te1/1/1 Desg FWD 2 128.53 P2p
Te1/1/3 Desg FWD 2 128.55 P2p
Te1/1/4 Desg FWD 2 128.56 P2p
Te1/1/5 Desg FWD 2 128.57 P2p
Te1/1/6 Desg FWD 2 128.58 P2p
Te1/1/7 Desg FWD 4 128.59 P2p
Te2/0/47 Desg FWD 4 128.143 P2p
Te2/1/1 Desg FWD 2 128.149 P2p
Te2/1/2 Desg FWD 2 128.150 P2p
Tw3/0/3 Desg FWD 4 128.195 P2p Edge
Tw3/0/6 Desg FWD 19 128.198 P2p Edge
Tw3/0/11 Desg FWD 4 128.203 P2p
Tw3/0/24 Desg FWD 19 128.216 P2p Edge
Tw3/0/26 Desg FWD 19 128.218 P2p
Te3/1/1 Desg FWD 2 128.245 P2p
Te3/1/2 Desg FWD 2 128.246 P2p
Po1 Root FWD 1 128.3049 P2p
SW-050#show spanning-tree interface gigabitEthernet 1/0/1
Mst Instance Role Sts Cost Prio.Nbr Type
MST0 Desg FWD 20000 128.1 P2p
SW-003#show spanning-tree int tenGigabitEthernet 2/0/47
Vlan Role Sts Cost Prio.Nbr Type
VLAN0001 Desg FWD 4 128.143 P2p
VLAN0010 Desg FWD 4 128.143 P2p
VLAN0100 Desg FWD 4 128.143 P2p
VLAN0600 Desg FWD 4 128.143 P2p
Any other suggestions?
So sorry it in my todo list but I have limit time.
Tonight I will do some test in lab and check solution
MHM
Gi1/0/1 Root BKN*20000 128.1 P2p Bound(PVST) *PVST_Inc <<- I make review the show spanning tree you recently attach it different than your previous post ??
I think I am not understanding what you are asking for me to provide for you?
What would you like me to provide for you from sw-3 and switch 50?
You have two SW and each o e run different stp modes
One run pvst other run mst
You change AP and since them the mst SW side show PVST_Inc?
I am correct?
As I mention I run lab and get same issue ans solve it.
Confirm the following
SW mst run one instance including all vlan
SW mst is root for all vlan (work fine and not work fine)
Lastly
Share the priority of PVST for all vlan
For confirmation:
SW-050#show spanning-tree summary
Switch is in mst mode (IEEE Standard)
Root bridge for: MST0
EtherChannel misconfig guard is enabled
Extended system ID is enabled
Portfast Default is enabled
PortFast BPDU Guard Default is enabled
Portfast BPDU Filter Default is disabled
Loopguard Default is enabled
UplinkFast is disabled
BackboneFast is disabled
Configured Pathcost method used is short (Operational value is long)
Name Blocking Listening Learning Forwarding STP Active
MST0 0 0 0 12 12
1 mst 0 0 0 12 12
SW-003#show spanning-tree summary
Switch is in rapid-pvst mode
Root bridge for: VLAN0052, VLAN0414, VLAN0600
VLAN0001 0 0 0 60 60
VLAN0002 0 0 0 9 9
VLAN0010 0 0 0 19 19
VLAN0052 0 0 0 6 6
VLAN0100 0 0 0 60 60
VLAN0101 0 0 0 15 15
VLAN0200 0 0 0 18 18
VLAN0300 0 0 0 3 3
VLAN0350 0 0 0 13 13
VLAN0411 0 0 0 9 9
VLAN0412 0 0 0 9 9
VLAN0414 0 0 0 2 2
VLAN0417 0 0 0 9 9
VLAN0500 0 0 0 19 19
VLAN0600 0 0 0 3 3
VLAN0603 0 0 0 13 13
VLAN0604 0 0 0 13 13
VLAN0810 0 0 0 21 21
VLAN0900 0 0 0 10 10
19 vlans 0 0 0 311 311
The interfaces that the APs are connected to on sw-3 and sw-50 are native VLAN 10. SO I am assuming you want the priority for VLAN 10 on SW-3
SW-003#show spanning-tree vlan 10 detail
VLAN0010 is executing the rstp compatible Spanning Tree protocol
Bridge Identifier has priority 8192, sysid 10, address acf5.e66e.7b80
Configured hello time 2, max age 20, forward delay 15, transmit hold-count 6
Current root has priority 4106, address c4b3.6a85.d480
Root port is 3049 (Port-channel1), cost of root path is 1
Topology change flag not set, detected flag not set
Number of topology changes 768 last change occurred 18:57:31 ago
from Port-channel1
Times: hold 1, topology change 35, notification 2
hello 2, max age 20, forward delay 15
Timers: hello 0, topology change 0, notification 0, aging 300
Port 17 (TwoGigabitEthernet1/0/17) of VLAN0010 is designated forwarding
Port path cost 19, Port priority 128, Port Identifier 128.17.
Designated root has priority 4106, address c4b3.6a85.d480
Designated bridge has priority 8202, address acf5.e66e.7b80
Designated port id is 128.17, designated path cost 1
Timers: message age 0, forward delay 0, hold 0
Number of transitions to forwarding state: 1
The port is in the portfast mode by default
Link type is point-to-point by default
Bpdu guard is enabled by default
Loop guard is enabled by default on the port
BPDU: sent 7334011, received 0
Port 19 (TwoGigabitEthernet1/0/19) of VLAN0010 is designated forwarding
Port path cost 19, Port priority 128, Port Identifier 128.19.
Designated port id is 128.19, designated path cost 1
BPDU: sent 7293760, received 0
Port 53 (TenGigabitEthernet1/1/1) of VLAN0010 is designated forwarding
Port path cost 2, Port priority 128, Port Identifier 128.53.
Designated port id is 128.53, designated path cost 1
BPDU: sent 8016918, received 1
Port 55 (TenGigabitEthernet1/1/3) of VLAN0010 is designated forwarding
Port path cost 2, Port priority 128, Port Identifier 128.55.
Designated port id is 128.55, designated path cost 1
BPDU: sent 8016917, received 1
Port 56 (TenGigabitEthernet1/1/4) of VLAN0010 is designated forwarding
Port path cost 2, Port priority 128, Port Identifier 128.56.
Designated port id is 128.56, designated path cost 1
BPDU: sent 8016925, received 1
Port 57 (TenGigabitEthernet1/1/5) of VLAN0010 is designated forwarding
Port path cost 2, Port priority 128, Port Identifier 128.57.
Designated port id is 128.57, designated path cost 1
BPDU: sent 921636, received 2
Port 58 (TenGigabitEthernet1/1/6) of VLAN0010 is designated forwarding
Port path cost 2, Port priority 128, Port Identifier 128.58.
Designated port id is 128.58, designated path cost 1
BPDU: sent 4990525, received 6
Port 59 (TenGigabitEthernet1/1/7) of VLAN0010 is designated forwarding
Port path cost 4, Port priority 128, Port Identifier 128.59.
Designated port id is 128.59, designated path cost 1
BPDU: sent 8016924, received 2
Port 143 (TenGigabitEthernet2/0/47) of VLAN0010 is designated forwarding
Port path cost 4, Port priority 128, Port Identifier 128.143.
Designated port id is 128.143, designated path cost 1
BPDU: sent 1979412, received 0
Port 149 (TenGigabitEthernet2/1/1) of VLAN0010 is designated forwarding
Port path cost 2, Port priority 128, Port Identifier 128.149.
Designated port id is 128.149, designated path cost 1
BPDU: sent 601089, received 0
Port 150 (TenGigabitEthernet2/1/2) of VLAN0010 is designated forwarding
Port path cost 2, Port priority 128, Port Identifier 128.150.
Designated port id is 128.150, designated path cost 1
Port 195 (TwoGigabitEthernet3/0/3) of VLAN0010 is designated forwarding
Port path cost 4, Port priority 128, Port Identifier 128.195.
Designated port id is 128.195, designated path cost 1
BPDU: sent 1691305, received 0
Port 198 (TwoGigabitEthernet3/0/6) of VLAN0010 is designated forwarding
Port path cost 19, Port priority 128, Port Identifier 128.198.
Designated port id is 128.198, designated path cost 1
BPDU: sent 8016197, received 0
Port 203 (TwoGigabitEthernet3/0/11) of VLAN0010 is designated forwarding
Port path cost 4, Port priority 128, Port Identifier 128.203.
Designated port id is 128.203, designated path cost 1
BPDU: sent 1691364, received 0
Port 216 (TwoGigabitEthernet3/0/24) of VLAN0010 is designated forwarding
Port path cost 19, Port priority 128, Port Identifier 128.216.
Designated port id is 128.216, designated path cost 1
BPDU: sent 5862542, received 0
Port 218 (TwoGigabitEthernet3/0/26) of VLAN0010 is designated forwarding
Port path cost 19, Port priority 128, Port Identifier 128.218.
Designated port id is 128.218, designated path cost 1
BPDU: sent 905235, received 5
Port 245 (TenGigabitEthernet3/1/1) of VLAN0010 is designated forwarding
Port path cost 2, Port priority 128, Port Identifier 128.245.
Designated port id is 128.245, designated path cost 1
BPDU: sent 598394, received 0
Port 246 (TenGigabitEthernet3/1/2) of VLAN0010 is designated forwarding
Port path cost 2, Port priority 128, Port Identifier 128.246.
Designated port id is 128.246, designated path cost 1
Port 3049 (Port-channel1) of VLAN0010 is root forwarding
Port path cost 1, Port priority 128, Port Identifier 128.3049.
Designated bridge has priority 4106, address c4b3.6a85.d480
Designated port id is 128.2377, designated path cost 0
Timers: message age 16, forward delay 0, hold 0
BPDU: sent 314, received 8008262
Should I just disable spanning tree on the interfaces the APs are connected to? I'm trying to wrap my head around this and I am failing to do so.
XXXXSW-050#show spanning-tree <<- your previous
MST0
Root ID Priority 4097
Address XXXX.6a85.XXXX
Cost 20001
Port 1 (GigabitEthernet1/0/1)
Address 0027.9006.YYYY
XXXXSW-050#show spanning-tree <<- share this which from xxxxSW
This is the current:
MST0
Address 0027.9006.a500
