Hi Guys,
I have a scenario where 15 c500 switches and 5 2960 8 port switch connected to 4507R core switch. There are 10 dhcp pools created on the 4507.
Eg: ip dhcp pool XXXX
network xxxx.xxxxxxx
default-router x.x.x.x
Now the default router is directed to vlans created on the switch i.e vlan 101, 102, 103 and so on. Now the remaining switches connected are configured to be in the same vlan. So the systems connected to the edge switches will get the DHCP ip automatically, Now my problem is after sometime (may be 2 or 3 hrs) all the edge switches are losing configuration automatically even though it's not restarted, even after saving the config on to nvram, everytime I connect the console and check all the saved config is lost, really need urgent help on this.
Krishna
