Configration the Port of Switch for the Camera
I would like to ask How I can confugration the Switch port for Camera ?
The commands which I need to put in the interface ? the same of when I have IP PHONE or there is something change?
Mark Malone
Heres one of mine , its just the vlan changes really , you can add qos and port-security as as extra if you decide too
all you really need is the vlan , the rest is optional but recommended
interface GigabitEthernet2/2/10
description HD Camera Do Not Move Port Secured
switchport access vlan 159
switchport mode access
switchport voice vlan 186
switchport port-security maximum 2
switchport port-security violation restrict
switchport port-security aging time 1
switchport port-security aging type inactivity
auto qos trust
spanning-tree portfast edge
spanning-tree bpduguard enable
service-policy input AutoQos-4.0-Input-Policy
service-policy output AutoQos-4.0-Output-Policy
ip dhcp snooping limit rate 7
end
Thank you for your replay
So just I need to put the interface on mode  access  with the vlan of Camera + the switchport voice vlan (voice vlan )
the voice vlan is not required we just have that applied to all ports default ignore it , if you remove all the optional there all you really need is the video vlan
I would recommend at least though using the STP commands too , they will help if theres any layer 2 issues
