01-19-2015 04:42 AM - edited 03-07-2019 10:17 PM
Hola, deseo hacerles una consulta, planeo instalar 200 nodos con un servicio de internet de 10/10mb utilizar un Cisco SG300-10SFP-K9 Small Bus Switch 10/100/1000 para balancear la carga de internet y subdividir a 4 Cisco Catalys 52-port Gigabit PoE Managed Switch y de ahi repartir los 200 nodos (obviamente tendre instalado un Rack con patch panel y todo el site listo
Necesito saber si con esos equipos sera suficiente para alimentar los 200 nodos (*cuartos)
Menciono que en cada nodo habra un wi fi router que proovera servicio de internet en cada cuarto*
Solved! Go to Solution.
01-19-2015 09:47 AM
01-19-2015 09:47 AM
Hello.
Please translate your question into English.
01-19-2015 04:36 PM
I planning to use 1 SG300-10SFP for internet boost
and 4 Cisco Catalys 52 -port Gigabit PoE
The connection I'm planning to do is like below
1# from ISP (Internet Provider 10/10mb simetric)
2# to (1) SG300-10SFP( for load balancing) from here
3# to feed 4 Cisco Catalys 52 -port Gigabit PoE and from here
4# to 190 Rooms (each room will have a Wi-fi 2 port router *190 small routers total)
each (room/router will have it own password accord to the room number) for example*
Please correct me if I'm wrong or i need any extra device like RJ45 transceivers
*The final use is to get Wi fi on each Room from the Hotel, because is and old construction with a lot of Metal and cement 12 floor
Thanks I hope you can help
01-19-2015 11:31 AM
Thanks for repliying
Hi, I want to make a query, I plan to install 200 nodes with an Internet service 10 / 10mb and use a SG300-10SFP-K9 Cisco Small Bus Switch 10/100/1000 for load balancing Internet and subdivide 4 Cisco Catalys 52 -port Gigabit PoE Managed Switch and from there spread to 200 nodes (obviously I'll have installed a rack with patch panel and the entire site ready)
I need to know if such equipment (devices) will be enough to feed 200 nodes (* rooms)
I mention that each node there will be a wi fi router proovera internet service in each room *
Thansk for the help
01-19-2015 12:51 PM
Hello.
Thanks for the translation.
I didn't get was device[s] will be doing load-balancing and NAT translation?
