upgrade inside host to ASA 5505
I bought an ASA 5505 (ASA5505-BUN-K9). I see the limit of 10 inside users.
What is the solution for upgrade this limit? Is there a license for increase this value?
I buy and install the license L-ASA5505-SECPL= but the limit of inside users is the same.
You are right, the SecPlus-Upgrade doesn't upgrade the internal host count. But it's not wasted money. Now you have a real DMZ, Trunk-Interfaces and much more.
For more internal users, you need the license ASA5505-SW-10-50= or ASA5505-SW-10-UL=.
BTW: This is the wrong forum, should be moved to Security/Firewall
ok, thanks very much Karsten
