Configuration differences between cat 9400 and 4500
f.fnlaspect
We are purchasing a cat 9407 and see this as the natural replacement for our 4507's.
Might be obvious but are they are any differences in configuration at all? Just wanted to know if there is anything to look out for. Should it just be planned that the same config will go from one to the other?
Thanks.
Mark Malone
They both actually now run IOS-XE so config should be identical , just make sure in config guide the version your moving to is not missing anything important but once you have same type license level you should be fine , 9ks are the replacements from 4ks , really its mostly hardware changes , software still IOS-XE unless very old 4ks they were IOS but even at that the changes are minimal coming from IOS - IOS-XE if thats the case , 9ks use stackwise 45s use VSS that will be different but ame ocncept , standard config , user end or routing switching commands are the same
here is a link to one of the 9k s latest configuration guides ,you can search commands there if you are bit uncertain but you shouldn't face any major changes
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst9400/software/release/16-10/configuration_guide/b-1610-9400-cg.html
Mark Elsen
 - If you talk about differences have a look at the table from the link below. Usually this will affect the configuration but initially migrate the IOS-config as is; and see if it bumps and or correct according to guidelines denoted by the new platform ;
  https://www.cisco.com/c/dam/en/us/products/collateral/switches/catalyst-9400-series-switches/nb-06-upgrading-cat-9400-fc-cte-en.pdf
M;
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
Mark Malone
Thanks Mark and Marcel.
