configuration EHWIC-3G-HSPA-U card on 2911
teymur azimov
Hi dears.
please provide me link how i configurate EHWIC-3G-HSPA+7   card on 2911.
thanks.
fb_webuser
Level 6
Level 6
http://www.cisco.com/en/US/docs/routers/access/1800/1861/software/feature/guide/mrwls_hspa.html#wp1323053
You need to use encapsulation SLIP instead of PPP (not suported in the interface)
for example with the Chat-script
chat-script hspa+ "" "AT!SCACT=1,1" TIMEOUT 60 "OK"
interface Cellular0
ip address negotiated
encapsulation slip
dialer in-band
dialer string hspa+
dialer-group 1
async mode interactive
ip route 0.0.0.0 0.0.0.0 Cellular0
dialer-list 1 protocol ip permit
line 0/0/0 ! for the fixed platforms (88x or 81x) use "line 3" instead of the line
0/0/0
exec-timeout 0 0
script dialer direct-ip
modem InOut
I hope that it helps; please rate it.
Posted by WebUser Pedro Seabra Ávila from Cisco Support Community App
Hi. thank you to help me.
i configurated 881g router. all of them are working perfectly. now i chanege 881 router to 2911 router.
this is my working configuration on 881g router.(i attached only 3g part).
chat-script gsm "" "ATDT*99*1#" TIMEOUT 30 "CONNECT"
license udi pid CISCO881G-K9 sn FCZ1446C14A
controller Cellular 0
interface Cellular0
no ip address
ip nat outside
ip nat enable
no ip virtual-reassembly in
encapsulation ppp
dialer in-band
dialer pool-member 1
dialer-group 1
interface Dialer1
ip nat outside
ip nat enable
encapsulation ppp
dialer pool 1
dialer idle-timeout 0
dialer string gsm
dialer persistent
dialer-group 1
ppp chap hostname norm
ppp chap password 0 norm
ppp ipcp dns request
now i want to do this same configuration on 2911 router. how i do this configuration on 2911?
(config-if)#encapsulation ppp
Cellular0/0/0: Only SLIP encapsulation supported
as you said the celleular is not supported ppp. how i do configuration on 2911 and it works as 881g.
thanks.
i must be use encapsulation pap not slip. is it possibly to use pap at this router or card?
