Configuration module supervisor Switch Catalyst 4500
Jhon Joseph Flores Osco
Community Member
Good afternoon I need a help regarding a switch catalyst 4500 with ios cat4500e-universal.SPA.03.02.00.XO.150-2.XO.bin
I need help in configuration modules 3 and 4 of supervision, the problem is that I need the 4-port module 3 are active but only the first turn on both the module 3 and the first port on the module 4.
please if anyone knows of this issue.
attachment of visualization:
CSFCoreCisco#show module
Chassis Type : WS-C4507R E
Power consumed by backplane : 40 Watts
Mod Ports Card Type                              Model              Serial No.
1    18  10GE (X2), 1000BaseX (SFP)             WS-X4606-X2-E      JAE161102E8
2    18  10GE (X2), 1000BaseX (SFP)             WS-X4606-X2-E      JAE161102C5
3     6  Sup 7L-E 10GE (SFP ), 1000BaseX (SFP)  WS-X45-SUP7L-E     CAT1609L2GR
4     6  Sup 7L-E 10GE (SFP ), 1000BaseX (SFP)  WS-X45-SUP7L-E     CAT1609L2AH
5    48  10/100/1000BaseT (RJ45)                WS-X4648-RJ45-E    JAE1609037W
M MAC addresses                    Hw  Fw           Sw               Status
1 442b.037a.379a to 442b.037a.37ab 1.2                               Ok
2 442b.037a.32d2 to 442b.037a.32e3 1.2                               Ok
3 f0f7.553a.9cc0 to f0f7.553a.9cc5 1.1 15.0(1r)SG3  03.02.00.XO      Ok
4 f0f7.553a.9cc6 to f0f7.553a.9ccb 1.1 15.0(1r)SG3  03.02.00.XO      Ok
5 c464.13e1.ae06 to c464.13e1.ae35 1.0                               Ok
Mod  Redundancy role     Operating mode      Redundancy status
3   Standby Supervisor  SSO                 Standby hot
4   Active Supervisor   SSO                 Active
Reza Sharifi
That is normal behavior.  Since you have SSO configured from the config guide:
When you use WS-X45-SUP7-E in RPR or SSO mode,  only the first two uplinks on each supervisor engine are available. The  second two uplinks are unavailable.
Here is the link for more info:
http://www.cisco.com/en/US/docs/switches/lan/catalyst4500/12.2/01xo/configuration/guide/RPR.html#wp1097897
