configuration of NM-16ESW on 3725
Hi all,
I use to configure network module NM-16ESW, but it doesn't work when this NM is inserted into 3725 IOS12.3(10).
I would like to configure port as follows:
interface FastEthernet2/13
description WAN to Suez over 1620
no switchport access vlan
ip address x.X.X.X 255.255.255.0
no shutdown
clns router isis djibouti
isis metric 3
end
I've got the following error message in conf mode:
djibrt103(config-if)#no switchport access vlan
djibrt103(config-if)#ip address 10.105.104.17 255.255.255.0
% IP addresses may not be configured on L2 links.
jiexu_llh
The NM-16ESW is Layer 2 Network Module card. You can only config IP address in vlan interface.Please read the Document as following.
http://www.cisco.com/c/en/us/support/docs/interfaces-modules/network-modules/82156-ether-switch-nm-config.html
Thank you very much for your answer.
But I disagree with you because, I have exactly the same board "NM-16ESW" inserted into a 2911 (with SM-NM adpator).
The following configuration perfectly works:
interface FastEthernet1/8
 no switchport
 ip address 10.103.30.2 255.255.255.248
 ip ospf cost 30
I'm wondering if the board features depend on the IOS ??
extract of sh diag
Slot 1:
        SM-NM-ADPTR
        Port Adapter is analyzed
        Port Adapter insertion time 9w5d ago
        EEPROM contents at hardware discovery:
        PCB Serial Number        : FOC14455113
        Hardware Revision        : 1.0
        Part Number              : 73-12434-04
        Top Assy. Part Number    : 800-32481-01
        Board Revision           : E0
        Deviation Number         : 0
        Fab Version              : 05
        RMA Test History         : 00
        RMA Number               : 0-0-0-0
        RMA History              : 00
        Product (FRU) Number     : SM-NM-ADPTR
       FastEthernet Port adapter, 16 ports
        Port adapter is analyzed
        Port adapter insertion time 9w5d ago
        Top Assy. Part Number    : 800-15156-02
        Board Revision           : D0
        Deviation Number         : 0-0
        Fab Version              : 03
        PCB Serial Number        : FOC144714GE
        RMA History              : 00
        Base MAC Address         : d0d0.fd3b.5536
        MAC Address block size   : 17
        Product (FRU) Number     : NM-16ESW
