configuration of switch
sunil-koul
can we configure new switch without console cable.does switch have default ip and telnet enabled by default.
cadet alain
no a switch doesn't have an IP configured by default and telnet is enabled but there is no password set nor any privileged enable password configured.
Regards.
Alain
There is a different way to configure a new switch without the need for console-access. But you have to build a complete "Install-Infrastructure" for that so it's only worth the effort if there are many switches to install. The feature is named "Smart Install":
http://www.cisco.com/en/US/partner/docs/switches/lan/smart_install/release_12.2_55_se/configuration/guide/concepts.html
Don't stop after you've improved your network! Improve the world by lending money to the working poor:
http://www.kiva.org/invitedby/karsteni
