configuration registor
jonk34567
Level 6
Level 6
if i set the value of configuration register to
     0x2102----load ios from flash
     0x2100----load ios from Rom
    0x2142-----?
may i know what will happen if configuration register is set to 0x2142
Palaniswamy P
Frequent Visitor
Frequent Visitor
On Reloading the router , it will bypass the running-config if the config-register is set to 0x2142.
Georg Pauwen
in addition to the other post, have a look at the document below, which lists the config register settings and what they do:
https://www.cisco.com/c/en/us/support/docs/routers/10000-series-routers/50421-config-register-use.html
